Habe nach dem Atmega32 gleich versucht den Atmega644 mit E2000 zu flashen. Dauerte wieder nicht länger als eine Sekunde und es kam das dabei raus:
Zitat:
avrdude -p m644 -b 115200 -c avr910 -P COM1 -e -U lfuse:w:0xff:m -U hfuse:w:0xd9:m -U flash:w:E2000-NET-IO.hex
Found programmer: Id = "AVR ISP"; type = S
Software Version = 3.8; Hardware Version = 1.2
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize = 64 bytes.
Programmer supports the following devices:
Device code: 0x13 = AT90S1200
Device code: 0x20 = ATtiny84
Device code: 0x28 = AT90S4414
Device code: 0x30 = AT90S4433
Device code: 0x34 = AT90S2333
Device code: 0x38 = AT90S8515
Device code: 0x48 = (unknown)
Device code: 0x4c = AT90S2343
Device code: 0x51 = (unknown)
Device code: 0x55 = ATtiny12
Device code: 0x56 = ATtiny15
Device code: 0x68 = AT90S8535
Device code: 0x6c = AT90S4434
Device code: 0xffffff86 = (unknown)
Device code: 0xffffff87 = (unknown)
Device code: 0x04 = (unknown)
Device code: 0x05 = (unknown)
Device code: 0x06 = (unknown)
Device code: 0x07 = (unknown)
Device code: 0x1a = (unknown)
Device code: 0x1b = (unknown)
Device code: 0x1c = (unknown)
Device code: 0x1d = (unknown)
Device code: 0x23 = (unknown)
Device code: 0x31 = (unknown)
Device code: 0x33 = (unknown)
Device code: 0x37 = (unknown)
Device code: 0x39 = (unknown)
Device code: 0x3d = (unknown)
Device code: 0x3e = (unknown)
Device code: 0x57 = (unknown)
Device code: 0x3a = ATMEGA8515
Device code: 0x3b = (unknown)
Device code: 0x41 = ATMEGA103
Device code: 0x43 = ATMEGA128
Device code: 0x44 = (unknown)
Device code: 0x45 = ATMEGA64
Device code: 0x46 = (unknown)
Device code: 0x5e = ATtiny2313
Device code: 0x60 = ATMEGA161
Device code: 0x61 = (unknown)
Device code: 0x62 = (unknown)
Device code: 0x63 = ATMEGA162
Device code: 0x64 = ATMEGA163
Device code: 0x66 = (unknown)
Device code: 0x69 = ATMEGA8535
Device code: 0x6a = (unknown)
Device code: 0x72 = ATMEGA32
Device code: 0x73 = (unknown)
Device code: 0x74 = ATMEGA6450
Device code: 0x75 = ATMEGA6490
Device code: 0x76 = ATMEGA8
Device code: 0x77 = (unknown)
Device code: 0x78 = ATMEGA169
Device code: 0x79 = (unknown)
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e960a
avrdude: Expected signature for ATMEGA644 is 1E 96 09
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Problem mit Firmware aufpsielen auf ATMEGA644
07.11.2011 - 20:28:31 Uhr
